Hi all, I’ve been lurking for a bit and wanted to pop out for a bit of input.
I’m in the process of setting up a test network using a collection of VPSs/servers at my disposal. I’m guessing I might be able to get by with the prebuilt safe_vault, but have been working on building from source. Currently I have been following:
(side note) I lost some time following the archive info, the readme should have some warnings/info…also the main vault repo would be nice if it contained some basic build instructions or at least a link to a list of dependencies etc.
Anyways, I have the repo cloned, installed rust, ran into errors, installed missing dependencies when prompted (ah the fun of build troubleshooting) and got stuck on building (cargo build --release) with the following errors:
Compiling safe_vault v0.18.0 (/home/graham/code/safe_vault)
error: lint private_no_mangle_fns has been removed: no longer an warning, #[no_mangle] functions always exported
→ src/lib.rs:206:5
206 | private_no_mangle_fns,
note: lint level defined here
→ src/lib.rs:196:5
196 | warnings
= note: #[forbid(renamed_and_removed_lints)] implied by #[forbid(warnings)]
error: lint private_no_mangle_statics has been removed: no longer an warning, #[no_mangle] statics always exported
→ src/lib.rs:207:5
207 | private_no_mangle_statics,
error: aborting due to 2 previous errors
error: Could not compile safe_vault.
Additionally, while it doesn’t seem to be an issue, this is preceded by:
warning: An explicit [[test]] section is specified in Cargo.toml which currently disables Cargo from automatically inferring other test targets.
I searched the forum, checked the verbose logs and did some basic google searching but wasn’t able to find anything that helps. I’d appreciate any input to resolving this!
OS: Ubuntu 16.04
Rust: Latest installed/relogged
Dependencies: pkg-config, libssl-dev, all the ones that building with c requires
Thanks!
