Hi everyone this is Will right now, but am sharing this account with several of our MaidSafe Asia members, as an official profile.
We are trying to run our own alpha network and using the droplet_deployer on Github. Everything’s working nicely and it’s great to have new tools like this these days. Have come a long way
It’s very strange though, we keep testing it and it gives different errors at different stages, not following any type of pattern which is unusual. Here are some error codes we get :: 502 :: 442
The biggest one we keep running into is “PERMISSION DENIED” (*see below) and I ran a chmod 777 on all the relevant files and folders but it still pops up sometimes.
Could anyone give any insight into setting up the network please, perhaps even a short Skype call at some point.
We have several ways we will use this network to keep promoting SAFE throughout Asia once we get this running, thank you. Perhaps @hunterlester@bochaco etc
Assuming you guys followed all the previous instructions as discussed on our call & chats, it looks like you are pretty close to completion here as you are at the stage of transferring your safe_vault & associated config files over to your nodes.
The IP that is listed in your screenshot - is that one of the nodes of your network? Or is this a server that you are using to scp the files over to each node?
I wonder if you are able to ssh to that machine using the details it prints on screen? And whether you are able to scp your generated files to the exact location on that machine as the code in your screenshot is trying to do? I assume you’ll be able to narrow down your issue a little by trying this.
If you are able to manually ssh and scp to this machine without any issues then I’d suggest just skipping the automated scp part of the droplet deployer script and write your own quick scp script, even just a quick 'for ip in xxx.xxx.xxx.xxx, xxx.xxx.xxx.xxx; do scp safe_vault qa@$ip:~/; done` would suffice in transferring the files over and unblocking you
If you would be constantly deploying networks then it would make sense to dig deeper but it sounds like this is more or less a 1 off scp for you guys.
I managed to start up the local testnet successfully. Also I’ve downloaded the Safe Browser and copied & renamed the config files over from the safe_vault.
Now I’m wondering if I still need to “Claim an Invitation” (get the Invitation Token) to create an account since I’m connecting to my own local testnet? Is there a way to bypass this token input since I’m running on my own testnet?
