Static website frameworks for SAFE Network
Static Frameworks and links to SAFE Topics on each
This post is a wiki so feel free to add to or edit the following list. These items have been restarted from 2024 since the earlier list further down began in 2020:
  • Publii is a desktop app that works very like the WordPress CMS to generate a blog website in static HTML, using WYSIWYG, block and markdown editors to create posts. It is GPL, runs on Linux, Windows and Mac, and has an online marketplace for templates and plugins, again similar to WordPress and it can even import posts from a WordPress blog. (website). There are many ways to generate static websites but Publii is particularly suitable for Safe Network and is exactly what I envisaged Safepress to be some years ago.
  • Svelte is a fantastic, easy to learn, fast framework that can be used to create static websites, so if you want something more powerful this is great option. It was used to create demos on the old Safe Network testnets years ago, but has been updated. Official docs on creating a static website are here, and this article on creating a static HTML blog is also a good tutorial on Svelte (website).
Older list (began in 2020):
Interesting, I like seeing tools like this, I have been playing with Vuejs with similar goals. It all depends on the site needs, but from the sounds of it Gatsby could be a great tool. I would see it benefiting from being paired with some sort of deployment script so users could manage their content wherever, then run a (node?) script pulling the content/files and uploading/updating the network.
Hey, @happybeing Yeah Gatsby is a great tool for generating progressive static websites, which is good for its performance. While planning for implementing DevHub website we were looking for some tool which should be developer friendly for developing and maintaining a static website and also increases its performance. Among many React-static and Gatsby seems to be good. They support all the latest toolsets like Webpack, React JS, ES6 and many others. We went on with React-static just because to use Gatsby we need to know GraphQL to fetch data whereas React-static just uses a simple XHR request (for example Axios). While considering performance Gatsby stood front. On the other hand, React-static provides inbuild SEO which we don’t need to worry about.
We have been using React-static for DevHub, safenetwork.tech and latest maidsafe.net websites.
Thanks @Shankar_S that’s very helpful to someone like me who hasn’t delved into either of these. Much appreciated.
FYI Ruben Verborgh has been pointing out the differences between SPARQL and GraphQL in a video at the head of this twitter thread (not watched myself yet):
https://mobile.twitter.com/RubenVerborgh/status/1076792994425118720
Thanks for the link. I’ll watch it :+1:
Not sure how important this is, but:
Thanks for sharing. That look’s interesting. Let me play with it :+1:
I made a post on the Solid forum looking for more info:
A bit more depth on React-static
  • React-static get started video (5min YouTube)
  • Walkthrough - Installing and creating a new project with Styled Components (20 min YouTube)
  • Introducing React-Static! How it works and why we built it! (80mins YouTube)
React-static looks very promising for building fast static sites for SAFE, and I think it would work well with a local CMS (which could be sync’d to SAFE, eg via SAFE Drive/SAFE git). I wonder if netlifycms.org could be adapted to give a decent CMS experience too.
The last one is very impressive - see ~15 mins onwards for details of how React-static works and why it is so fast. Looks like an ideal way to generate very fast static sites for SAFE.
I made a few notes on the last video above…
Comments: (06:00)
	Next.js - not fast, feels Wordpressy, very popular
	Phenomic - poor dev exp
	Gatsby.js - fast, feels like forces GraphQL which is not needed for blogs etc. Not great dev experience, reliance on plugins to modify anything.
React-static data sources (e.g. Contentful, WordPress, Markdown, JSON etc)
	- Tanner uses Contentful (like WordPress but without front-end)
	- Contentful -> React-static -> HTML + JSON (for every page on the site)
	- uses Netlify to deploy (drag and drop folder), autobuild from github, free for low traffic sites
	- FAST (~15min):
		HTML loads page with full visual, then react-app loads behind and gives full interactivity/effects etc.
		Navigation only loads JSON (so very fast - uses React Router so no need to load HTML, react-app etc)
		You can preload links to make it even faster
		Offline - entire website can pre-load and browse without internet connection
	Code (31:15 mins)
	static.config.js
		- /public - put static assets in here
		- getRoutes() - gets the data (e.g. from WordPress etc) returns an array of paths (obj, path key, path to export) <- GOOD
			here you can decide to pre-load, or fetch on load etc.
		Build minifies and excludes anything you aren't using
		- HTML page customisation (39mins)
	src/index.js
		- sets everything up (probably don't need to touch)
	src/App.js (42mins)
		- defines pages, navigation etc
		- each page is a React component (a JS file)
		- Blog.js more complex defines a 'higher order component' using getRouteProps() (45:20mins)
			getRouteProps() ensures posts is available elsewhere using getProps({posts}) (see static.config.js)
		static.config.js (52:00 mins)
				const { data: { posts } = await axios.get('some url')
		is same as
			const resp = await axios.get('some url')
			const { data } = resp
			const { post } = data
		- customise page title (52:10 mins)
		- SEO sitemap setting (59:15mins)
		- load progress bar NProgress.js (01:03:40)
		- prefetch links (01:04:35)
	web hooks to auto re-build (netlify site) when data on github, Contentful etc change
	Netlify CMS (video 01:18:05)
Latest features in React-static v6: React Static v6!. The latest version packs a punch with… | by Tanner Linsley | Medium
This Tanner :slight_smile:
As the old-school guy he is referring to I did find this useful also:
medium.com/@tannerlinsley/️-introducing-react-static-a-progressive-static-site-framework-for-react
I’ve used react-static for multiple large, complex, production-ready websites and I highly recommend it. It’s significantly simpler and more flexible compared to big frameworks like Next.js or Gatsby. The new react-static v6 plugins are also a breeze to use and publish for shared SAFE functionality, if desired.
Big frameworks like Gatsby are great for creating an initial website for you, but as soon as you realize you want something even remotely customized, they tend to get in your way rather than helping. Just my two cents.
I stumbled on a couple of neat looking React libraries for data presentation among other things. The github page has animated demos, so worth a visit:
I’ve been playing with React-static and am liking it a lot. Still not tried Gatsby.js!
Today Tanner Linsley who created React-static shared this about Ionic 4 - it provides customisable framework agnostic components for Web and mobile apps. Sounds very good, and possibly a great cross platform option - anyone have experience / comment on this? @Shankar_S @bochaco @joshuef @cooperka See:
I’m learning a lot from Tanner (and I have a lot to learn about front end development) and here’s something else that he shared: CodeSandbox. This blew me away, here’s a link he shared so people can play with the update to React-table that he’s working on:
https://codesandbox.io/s/m5lxzzpz69
Ionic 4 sounds like a major step forward, but they still haven’t sold me on why I should use it… if I’m making a mobile-friendly website I’ll use React, if I’m making a mobile app with native features (like camera) I’ll use React Native, and if I want the exact same thing on both mobile and web (highly unlikely) I’ll use react-native-web.
Is the benefit just that Ionic 4 lets you publish existing websites as mobile apps and run them in a webview, sort of like Cordova but better? Maybe I’m missing the point :upside_down_face:
Hey @happybeing thanks for sharing with us. No I haven’t used Ionic before, but now as web component they sounds interesting for me.
@cooperka I’ve only read the linked blog announcement, which is useful because it gives the history and then explains what is such a big deal with Ionic 4. What I understand is that you can use Ionic components, including any customisations and derived components of your own, in any popular framework, so Angular, Vue, React etc, and that they put a lot of effort into making them fast, compact, slick etc.
With the rapid turnover of frameworks, and easier handling of different platforms, it sounds a good way to reduce effort and keep apps fresh. Anyway, Tanner was enthusiastic, which I take as :clap:
:wink:
I see, that sounds useful indeed. I suppose you could do something similar with React and e.g. use those components inside of a primarily Angular app, but it may not be as smooth of an integration. I want to play around with this, thanks for the links!
For wordpress, there are a few options. Free-est seems to be: Simply Static – The WordPress Static Site Generator – WordPress plugin | WordPress.org
I think speed will be an important factor for making effective Web apps and websites on SAFE Network.
Most websites so far built on SAFE tend to be sluggish when you click on a link etc, but it doesn’t have to be this way.
The following shows that we can have blazing fast websites on SAFE Network by using the same tech designed to create the fastest sites on the Web.
React-static does this not just by creating a static website, but by making each page compact and bundled, along with built in preloading of linked pages just in time for the visitor to click on them (e.g. on page load, or when a link scrolls into view etc).
The following demo shows the same React-static website on both Web and SAFE, and can be used by anyone as a starting point for testing this out or developing their own super fast website, with all the power of React.
After adding new content or editing a page you can build your website and automatically upload it to Web and/or SAFE Network with one command.
UPDDATE: see also:
https://dweb.happybeing.com
Update on React Static:
TLDR; Tanner Linsley is moving on, looking for other to maintain RS.
RS is a very nice option so I hope it continues to be developed.
EDIT: React Static has a new sponsor and maintainers so all is good :smile:
