Create your content locally in markdown and then publish to web and/or SAFE Network. Here is the demo Blog live:
- Web: rsdemo.markhughes.com
- DWeb: safe://rsdemo
Clone this repo to create a Blog website/app for Web and/or SAFE Network that will load blazing fast because it is based on React-static.
Deployment
On Linux this is automatic using a bash script with FTP (with ncftpput) and/or SAFE Drive:
$ scripts/deploy.sh
yarn run v1.12.3
$ react-static build
=> Info: No 'siteRoot' is defined in 'static.config.js'. This is suggested for absolute urls and also required to automatically generate a sitemap.xml.
=> Cleaning dist...
=> [✓] Dist cleaned
=> Building Routes...
=> [✓] Routes Built (0.4s)
=> Building Templates
=> [✓] Templates Built
=> Copying public directory...
=> [✓] Public directory copied
=> Bundling App...
Version: webpack 4.29.0
Time: 2336ms
Built at: 2019-01-29 12:24:18
Asset Size Chunks Chunk Names
main.63b9e5bf.js 5.26 KiB 0 [emitted] main
main.63b9e5bf.js.map 18.1 KiB 0 [emitted] main
styles.85db626c.css 336 bytes 6 [emitted] styles
templates/src-containers-Post.88917035.js 444 bytes 1 [emitted] src-containers-Post
templates/src-containers-Post.88917035.js.map 1.08 KiB 1 [emitted] src-containers-Post
templates/src-pages-404.0b0868a6.js 306 bytes 2 [emitted] src-pages-404
templates/src-pages-404.0b0868a6.js.map 610 bytes 2 [emitted] src-pages-404
templates/src-pages-about.f8ca561e.js 3.56 KiB 3 [emitted] src-pages-about
templates/src-pages-about.f8ca561e.js.map 10.5 KiB 3 [emitted] src-pages-about
templates/src-pages-blog.e4e07055.js 541 bytes 4 [emitted] src-pages-blog
templates/src-pages-blog.e4e07055.js.map 1.31 KiB 4 [emitted] src-pages-blog
templates/src-pages-index.1b49daf0.js 3.65 KiB 5 [emitted] src-pages-index
templates/src-pages-index.1b49daf0.js.map 10.7 KiB 5 [emitted] src-pages-index
templates/styles.85db626c.js 126 bytes 6 [emitted] styles
templates/styles.85db626c.js.map 105 bytes 6 [emitted] styles
templates/vendors~main.e5b6c10a.js 264 KiB 7 [emitted] vendors~main
templates/vendors~main.e5b6c10a.js.map 901 KiB 7 [emitted] vendors~main
[0] /home/mrh/src/safe-react/rs-blog-demo/node_modules/react/index.js 189 bytes {7} [built]
[1] /home/mrh/src/safe-react/rs-blog-demo/node_modules/react-hot-loader/index.js 676 bytes {7} [built]
[2] /home/mrh/src/safe-react/rs-blog-demo/node_modules/@babel/runtime/helpers/typeof.js 817 bytes {7} [built]
[3] (webpack)/buildin/module.js 552 bytes {7} [built]
[5] /home/mrh/src/safe-react/rs-blog-demo/node_modules/path-browserify/index.js 6.02 KiB {7} [built]
[6] /home/mrh/src/safe-react/rs-blog-demo/node_modules/babel-plugin-universal-import/universalImport.js 888 bytes {7} [built]
[8] ../lib/browser/index.js 25.8 KiB {7} [built]
[15] ../lib/browser/components/StaticInfo.js 3.02 KiB {7} [built]
[25] /home/mrh/src/safe-react/rs-blog-demo/dist/react-static-browser-plugins.js 144 bytes {0} [built]
[33] /home/mrh/src/safe-react/rs-blog-demo/dist/react-static-templates.js 3.33 KiB {0} [built]
[46] multi ../lib/bootstrapPlugins.js ../lib/bootstrapTemplates.js ../lib/bootstrapApp.js 52 bytes {0} [built]
[47] ../lib/bootstrapPlugins.js 942 bytes {7} [built]
[74] ../lib/bootstrapTemplates.js 715 bytes {7} [built]
[81] ../lib/bootstrapApp.js 1.98 KiB {7} [built]
[106] /home/mrh/src/safe-react/rs-blog-demo/src/index.js + 1 modules 1.02 KiB {0} [built]
| /home/mrh/src/safe-react/rs-blog-demo/src/index.js 581 bytes [built]
| /home/mrh/src/safe-react/rs-blog-demo/src/App.js 436 bytes [built]
+ 94 hidden modules
WARNING in asset size limit: The following asset(s) exceed the recommended size limit (244 KiB).
This can impact web performance.
Assets:
templates/vendors~main.e5b6c10a.js (264 KiB)
WARNING in entrypoint size limit: The following entrypoint(s) combined asset size exceeds the recommended limit (244 KiB). This can impact web performance.
Entrypoints:
main (269 KiB)
styles.85db626c.css
main.63b9e5bf.js
Child extract-css-chunks-webpack-plugin ../../css-loader/dist/cjs.js??ref--4-oneOf-2-1!../../postcss-loader/src/index.js??postcss!../../../src/app.css:
[0] /home/mrh/src/safe-react/rs-blog-demo/node_modules/css-loader/dist/cjs.js??ref--4-oneOf-2-1!/home/mrh/src/safe-react/rs-blog-demo/node_modules/postcss-loader/src??postcss!/home/mrh/src/safe-react/rs-blog-demo/src/app.css 624 bytes {0} [built]
[1] /home/mrh/src/safe-react/rs-blog-demo/node_modules/css-loader/dist/runtime/api.js 2.35 KiB {0} [built]
=> There were WARNINGS during the prod build stage. Your site will still function, but you may achieve better performance by addressing the warnings above.
=> [✓] App Bundled (2.6s)
=> Fetching Site Data...
=> [✓] Site Data Downloaded
=> Fetching Route Data...
=> [=======] 7/7 100% 7000/s 0.0s
=> [✓] Route Data Downloaded
=> Exporting HTML across 8 threads...
=> [=======] 7/7 100% 31/s 0.0s
=> [✓] HTML Exported (3s)
Done in 7.27s
FTP upload...
./dist/404/routeInfo.json: 82.00 B 1.00 kB/s
./dist/404.html: 1.34 kB 17.38 kB/s
./dist/about/index.html: 1.70 kB 12.91 kB/s
./dist/about/routeInfo.json: 303.00 B 3.33 kB/s
./dist/blog/index.html: 1.98 kB 22.82 kB/s
./dist/blog/routeInfo.json: 517.00 B 6.29 kB/s
./dist/blog/post/another-post.md/index.html: 1.47 kB 18.04 kB/s
./dist/blog/post/another-post.md/routeInfo.json: 193.00 B 3.13 kB/s
./dist/blog/post/testing-deploy-script.md/index.html: 1.65 kB 20.42 kB/s
...blog/post/testing-deploy-script.md/routeInfo.json: 367.00 B 4.33 kB/s
./dist/blog/post/an-example-post.md/index.html: 1.49 kB 18.52 kB/s
./dist/blog/post/an-example-post.md/routeInfo.json: 215.00 B 3.13 kB/s
./dist/client-stats.json: 2.32 MB 145.09 kB/s
./dist/index.html: 2.41 kB 29.80 kB/s
./dist/main.63b9e5bf.js: 5.26 kB 52.80 kB/s
./dist/main.63b9e5bf.js.map: 18.15 kB 72.12 kB/s
./dist/react-static-browser-plugins.js: 163.00 B 1.98 kB/s
./dist/react-static-build-config.json: 3.30 kB 29.74 kB/s
./dist/react-static-templates.js: 993.00 B 11.10 kB/s
./dist/robots.txt: 14.00 B 196.77 B/s
./dist/routeInfo.json: 673.00 B 8.63 kB/s
./dist/static.226b95f1.js: 178.74 kB 107.93 kB/s
./dist/static.226b95f1.js.map: 209.40 kB 117.97 kB/s
./dist/styles.85db626c.css: 336.00 B 4.22 kB/s
./dist/templates/src-pages-index.1b49daf0.js.map: 10.71 kB 14.77 kB/s
./dist/templates/src-pages-about.f8ca561e.js.map: 10.46 kB 55.14 kB/s
./dist/templates/src-pages-index.1b49daf0.js: 3.65 kB 30.23 kB/s
./dist/templates/src-pages-blog.e4e07055.js.map: 1.31 kB 14.32 kB/s
./dist/templates/vendors~main.e5b6c10a.js: 263.59 kB 142.45 kB/s
./dist/templates/vendors~main.e5b6c10a.js.map: 900.72 kB 151.88 kB/s
./dist/templates/src-pages-about.f8ca561e.js: 3.56 kB 21.33 kB/s
./dist/templates/styles.85db626c.js: 126.00 B 1.33 kB/s
./dist/templates/styles.85db626c.js.map: 105.00 B 1.54 kB/s
./dist/templates/src-containers-Post.88917035.js: 444.00 B 4.38 kB/s
./dist/templates/src-pages-blog.e4e07055.js: 541.00 B 4.11 kB/s
./dist/templates/src-containers-Post.88917035.js.map: 1.08 kB 12.29 kB/s
./dist/templates/src-pages-404.0b0868a6.js: 306.00 B 3.61 kB/s
./dist/templates/src-pages-404.0b0868a6.js.map: 610.00 B 6.63 kB/s
Mount SAFE Drive and press ENTER to sync... scripts/deploy.sh: 24: read: arg count
Syncing via SAFE Drive...
sending incremental file list
deleting main.css
404.html
client-stats.json
index.html
main.63b9e5bf.js
robots.txt
routeInfo.json
static.226b95f1.js
styles.85db626c.css
404/
404/routeInfo.json
about/
about/index.html
blog/
blog/index.html
blog/routeInfo.json
blog/post/
templates/
sent 4,108,426 bytes received 789 bytes 2,718.63 bytes/sec
total size is 4,104,329 speedup is 1.00
