Progressive Web App to Google Play Store:
Cool. I just did a bit of research and it seems the link you shared is related to updates in Chromium:
Appmaker requires registering for you to generate an APK, but it should be quite easy to do native using the ‘Trusted Web Activity’ from above.
thanks. My work on apknite will be easier from now.
