Trouble building dev browser
Ps: I’ve also experience with Bash scripting.
Cool, so by all means hack mine - once I’ve done with it I’ll offer a pull request and then it’s everybody’s.
Update:
I was doing yarn start, before doing just yarn, and that was the problem.
Thanks hunterlester!
I did:
export NODE_ENV=dev
yarn start
But I am still getting the javascript error :slight_smile: I also tried with set NODE_ENV=dev
Do I have to change this setting somewhere else?
Thanks!
Make sure you follow these steps;
  • Are you on latest master?
  • NODE_ENV=dev yarn
  • Either yarn mock-dev for mock routing
  • Or yarn prod-dev to connect to Alpha2 network
To verify:
cd into peruse\app\node_modules\@maidsafe\safe-node-app\src\native
You’ll see 2 directories named mock and prod. Open each one up and see that you have the expected libraries.
On my system I have .dll files:
lib_files
On your system you should see .dylib extensions.
Thank you, @hunterlester!
NODE_ENV=dev yarn
Well now, those three revelations will probably make a whole lot of difference to me too, seeing as this is the first time I’ve ever laid eyes on them. :slight_smile: Both of the guides I’ve been following have referred to:
NODE_ENV=dev
and
yarn mock
for mock routing. Neither of them mentions “NODE_ENV=dev yarn” nor “yarn mock-dev”. I may make more progress tomorrow now… :smiley:
