David explains how to speed up your Rust builds by 16x times and is working to build an incremental linker to speed it up even further:
https://davidlattimore.github.io/working-on-rust-iteration-time.html
Another aid to Rust compilation times, or execution speed, or binary size made easy using cargo install cargo-wizard:
