Currently you can’t tell from the outside. Overall our (HTTP)-Error-Codes are a bit cryptic and applied to broadly. We most obvious being a differentiation between launcher-side errors (like this one, generally in the 500-range) and client-side errors (in the 400-range). Like for this case, I’d say that 511 Network Authentication Required should be returned instead. Right now, it isn’t though.
We have a draft in the drawer to provide more specific codes and information, but that requires some bigger changes in the underlying things, too, and we aren’t sure yet whether we want to continue down that path.
another thing, that perhaps might want it’s own thread… not sure:
Can we at some juncture get the full API errors displayed in the launcher?
I was thinking, short version as we have it, but click for full error? It could be quite useful for application debug, especially if we can display the key info nicely. Node debugging of fetch requests is less than fun…
Just to say, the reason phrases can be changed within the specification. So, if there isn’t an appropriate code, an existing code can be used with a different reason phrase, e.g. 401 Unauthorised, 401 Invalid Credentials, etc.
“The individual values of the numeric status codes defined for HTTP/1.1, and an example set of corresponding Reason-Phrase’s, are presented below. The reason phrases listed here are only recommendations – they MAY be replaced by local equivalents without affecting the protocol.”
