The whole debug output file is rather long. I can post it somewhere if you like. This is the relevant section though I think. cd-ing into a SAFE folder _public/jpl/root-safe-blues and from there trying to copy a small text file hello2 into the same directory. Peruse 0.7.0.
Summary
unique: 342, success, outsize: 144
unique: 343, opcode: LOOKUP (1), nodeid: 10, insize: 56, pid: 6026
LOOKUP /_public/jpl/root-safe-blues
getattr /_public/jpl/root-safe-blues
safe-fuse:ops getattr('/_public/jpl/root-safe-blues') +0ms
safe-fuse:vfs-cache VfsCacheMap.getattr(/_public/jpl/root-safe-blues) +0ms
NODEID: 11
unique: 343, success, outsize: 144
unique: 344, opcode: LOOKUP (1), nodeid: 11, insize: 47, pid: 6026
LOOKUP /_public/jpl/root-safe-blues/hello2
getattr /_public/jpl/root-safe-blues/hello2
safe-fuse:ops getattr('/_public/jpl/root-safe-blues/hello2') +0ms
safe-fuse:vfs-cache VfsCacheMap.getattr(/_public/jpl/root-safe-blues/hello2) +0ms
safe-fuse:vfs:index getHandler(/_public/jpl/root-safe-blues/hello2) +6s
safe-fuse:vfs:index getHandler(/_public/jpl/root-safe-blues) +0ms
safe-fuse:vfs:index getHandler(/_public/jpl) +0ms
safe-fuse:vfs:index getHandler(/_public) +0ms
safe-fuse:vfs:root getHandlerFor(/_public) - containerRef: { safePath: '_public', safeUri: undefined }, mountPath: /_public +6s
safe-fuse:vfs:root getHandlerFor(/_public/jpl) - containerRef: { safePath: '_public', safeUri: undefined }, mountPath: /_public +0ms
safe-fuse:vfs:root getHandlerFor(/_public/jpl/root-safe-blues) - containerRef: { safePath: '_public', safeUri: undefined }, mountPath: /_public +0ms
safe-fuse:vfs:root getHandlerFor(/_public/jpl/root-safe-blues/hello2) - containerRef: { safePath: '_public', safeUri: undefined }, mountPath: /_public +0ms
safenetworkjs:container PublicContainer.itemAttributesResultRef('jpl/root-safe-blues/hello2') +6s
safenetworkjs:container PublicContainer.itemType('jpl/root-safe-blues/hello2') +0ms
safenetworkjs:web getMutableDataValueVersion([object Object],_public/jpl/root-safe-blues/hello2)... +6s
safenetworkjs:web -106: Core error: Routing client error -> Requested entry not found
safenetworkjs:web at module.exports (/home/user/safe-fuse-test/safenetworkjs/node_modules/@maidsafe/safe-node-app/src/native/_error.js:19:10)
safenetworkjs:web at args.push.ffi.Callback.restArgs (/home/user/safe-fuse-test/safenetworkjs/node_modules/@maidsafe/safe-node-app/src/native/_base.js:92:27)
safenetworkjs:web at /home/user/safe-fuse-test/safenetworkjs/node_modules/ffi/lib/callback.js:66:25 +70ms
safenetworkjs:web getMutableDataValueVersion() WARNING no entry found for key '_public/jpl/root-safe-blues/hello2' +0ms
safenetworkjs:container PublicContainer._getShortestEnclosingKey('jpl/root-safe-blues/hello2/') +70ms
safenetworkjs:container Matching path: _public/jpl/root-safe-blues/hello2/ +0ms
safenetworkjs:container entriesList: [ { key: <Buffer@0x7f58b4031f10 5f 70 75 62 6c 69 63 2f 6a 70 6c 2f 72 6f 6f 74 2d 73 61 66 65 2d 62 6c 75 65 73>,
safenetworkjs:container value:
safenetworkjs:container { buf: <Buffer@0x2d91688 0b 10 af 57 0d f9 77 6a 2b 98 4e 6a aa 9c e8 78 c6 ef 51 ee 2e ac 16 9b 00 1c 14 90 6a 84 f1 1a>,
safenetworkjs:container version: 0 } } ] +95ms
safenetworkjs:container Key : _public/jpl/root-safe-blues +1ms
safenetworkjs:container Key : _public/jpl/root-safe-blues +0ms
safenetworkjs:container Matching against: _public/jpl/root-safe-blues/hello2/ +0ms
safenetworkjs:container MATCH RESULT: <no match> +0ms
safenetworkjs:container PublicContainer.callFunctionOnItem(jpl/root-safe-blues/hello2, itemType, p2, p3, p4, p5) +0ms
safenetworkjs:container entriesList: [ { key: <Buffer@0x7f58b40321f0 5f 70 75 62 6c 69 63 2f 6a 70 6c 2f 72 6f 6f 74 2d 73 61 66 65 2d 62 6c 75 65 73>,
safenetworkjs:container { buf: <Buffer@0x2d916e8 0b 10 af 57 0d f9 77 6a 2b 98 4e 6a aa 9c e8 78 c6 ef 51 ee 2e ac 16 9b 00 1c 14 90 6a 84 f1 1a>,
safenetworkjs:container Value (encrypted):
�wj+�Nj���x��Q�.�#�##�j��# +1ms################�W
safenetworkjs:container Value :
wj+Nj踆.# +0ms###############################W
safenetworkjs:container Version: 0 +0ms
safenetworkjs:container Match Key : _public/jpl/root-safe-blues +0ms
safenetworkjs:container PublicContainer._getContainerForKey('_public/jpl/root-safe-blues') +0ms
safenetworkjs:container NfsContainer.itemType('hello2') +0ms
safenetworkjs:file NfsContainerFiles._fetchFileState('hello2', +6s)
safenetworkjs:file no entry found for: hello2 +83ms
safenetworkjs:web getMutableDataValueVersion([object Object],hello2)... +276ms
safenetworkjs:web at /home/user/safe-fuse-test/safenetworkjs/node_modules/ffi/lib/callback.js:66:25 +86ms
safenetworkjs:web getMutableDataValueVersion() WARNING no entry found for key 'hello2' +0ms
safenetworkjs:container NfsContainer._getShortestEnclosingKey('hello2/') +169ms
safenetworkjs:container Matching path: hello2/ +0ms
safenetworkjs:container entriesList: [ { key: <Buffer@0x7f58b4031400 53 61 66 65 2d 61 75 74 68 2d 6c 6f 67 2d 30 31 30 39 31 37 2e 74 78 74>,
safenetworkjs:container { buf: <Buffer@0x2d91798 9f 21 01 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 30 2e 34 30 31 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container version: 0 } },
safenetworkjs:container { key: <Buffer@0x7f58b40314a0 53 61 66 65 2d 62 72 6f 73 77 65 72 2d 6c 6f 67 2d 30 31 30 39 31 37 2e 74 78 74>,
safenetworkjs:container { buf: <Buffer@0x2d91810 f4 15 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 31 2e 33 30 37 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b4031550 5f 6d 65 74 61 64 61 74 61>,
safenetworkjs:container { buf: <Buffer@0x2d91888 01 2f 00 00 00 00 00 00 00 53 65 72 76 69 63 65 20 52 6f 6f 74 20 44 69 72 65 63 74 6f 72 79 20 66 6f 72 3a 20 6a 70 6c 2f 72 6f 6f 74 2d 73 61 66 65 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b4031600 62 6c 75 65 73 2e 6d 70 33>,
safenetworkjs:container { buf: <Buffer@0x2d91908 80 3e 0b 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 32 2e 32 36 31 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b40316a0 62 6c 75 65 73 32 2e 6d 70 33>,
safenetworkjs:container { buf: <Buffer@0x2d91980 00 a7 0a 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 35 2e 35 34 37 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b4031740 63 73 73 2f 62 67 31 2e 6a 70 67>,
safenetworkjs:container { buf: <Buffer@0x2d919f8 83 02 01 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 38 2e 34 31 34 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b40317e0 63 73 73 2f 73 74 79 6c 65 31 2e 63 73 73>,
safenetworkjs:container { buf: <Buffer@0x2d91a70 30 04 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 39 2e 34 31 35 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b4031880 66 61 76 69 63 6f 6e 2e 69 63 6f>,
safenetworkjs:container { buf: <Buffer@0x2d91ae8 be 10 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 31 30 2e 30 33 32 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b4031920 69 6e 64 65 78 2e 68 74 6d 6c>,
safenetworkjs:container { buf: <Buffer@0x2d91b60 23 03 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 31 30 2e 38 31 35 5a 1b 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container version: 0 } } ] +94ms
safenetworkjs:container Key : Safe-auth-log-010917.txt +4ms
safenetworkjs:container Key : Safe-broswer-log-010917.txt +0ms
safenetworkjs:container Key : _metadata +0ms
safenetworkjs:container Key : blues.mp3 +0ms
safenetworkjs:container Key : blues2.mp3 +0ms
safenetworkjs:container Key : css/bg1.jpg +0ms
safenetworkjs:container Key : css/style1.css +0ms
safenetworkjs:container Key : favicon.ico +0ms
safenetworkjs:container Key : index.html +0ms
safenetworkjs:container Key : Safe-auth-log-010917.txt +0ms
safenetworkjs:container Matching against: hello2/ +0ms
safenetworkjs:container hello2 is type: not-found +0ms
safenetworkjs:container loop result-2: 'not-found' +0ms
safenetworkjs:container Object.call returning result: 'not-found' +0ms
safenetworkjs:container itemType(jpl/root-safe-blues/hello2) returning: not-found +0ms
safenetworkjs:container PublicContainer._clearResultForPath(jpl/root-safe-blues/hello2) +0ms
safe-fuse:vfs-cache getattr('/_public/jpl/root-safe-blues/hello2') result type: not-found reply(Fuse.ENOENT) +530ms
unique: 344, error: -2 (No such file or directory), outsize: 16
unique: 345, opcode: LOOKUP (1), nodeid: 11, insize: 47, pid: 6026
safe-fuse:ops getattr('/_public/jpl/root-safe-blues/hello2') +531ms
safe-fuse:vfs-cache VfsCacheMap.getattr(/_public/jpl/root-safe-blues/hello2) +1ms
safe-fuse:vfs:index getHandler(/_public/jpl/root-safe-blues/hello2) +531ms
safe-fuse:vfs:root getHandlerFor(/_public) - containerRef: { safePath: '_public', safeUri: undefined }, mountPath: /_public +531ms
safenetworkjs:container PublicContainer.itemAttributesResultRef('jpl/root-safe-blues/hello2') +1ms
safenetworkjs:web getMutableDataValueVersion([object Object],_public/jpl/root-safe-blues/hello2)... +99ms
safenetworkjs:web at /home/user/safe-fuse-test/safenetworkjs/node_modules/ffi/lib/callback.js:66:25 +67ms
safenetworkjs:container PublicContainer._getShortestEnclosingKey('jpl/root-safe-blues/hello2/') +67ms
safenetworkjs:container entriesList: [ { key: <Buffer@0x7f58b40324d0 5f 70 75 62 6c 69 63 2f 6a 70 6c 2f 72 6f 6f 74 2d 73 61 66 65 2d 62 6c 75 65 73>,
safenetworkjs:container { buf: <Buffer@0x2d91d78 0b 10 af 57 0d f9 77 6a 2b 98 4e 6a aa 9c e8 78 c6 ef 51 ee 2e ac 16 9b 00 1c 14 90 6a 84 f1 1a>,
safenetworkjs:container version: 0 } } ] +98ms
safenetworkjs:container entriesList: [ { key: <Buffer@0x7f58b40327b0 5f 70 75 62 6c 69 63 2f 6a 70 6c 2f 72 6f 6f 74 2d 73 61 66 65 2d 62 6c 75 65 73>,
safenetworkjs:container { buf: <Buffer@0x2d91dd8 0b 10 af 57 0d f9 77 6a 2b 98 4e 6a aa 9c e8 78 c6 ef 51 ee 2e ac 16 9b 00 1c 14 90 6a 84 f1 1a>,
safenetworkjs:container version: 0 } } ] +99ms
safenetworkjs:file NfsContainerFiles._fetchFileState('hello2', +451ms)
safenetworkjs:file no entry found for: hello2 +56ms
safenetworkjs:web getMutableDataValueVersion([object Object],hello2)... +255ms
safenetworkjs:web at /home/user/safe-fuse-test/safenetworkjs/node_modules/ffi/lib/callback.js:66:25 +51ms
safenetworkjs:container NfsContainer._getShortestEnclosingKey('hello2/') +107ms
safenetworkjs:container entriesList: [ { key: <Buffer@0x7f58b40319f0 53 61 66 65 2d 61 75 74 68 2d 6c 6f 67 2d 30 31 30 39 31 37 2e 74 78 74>,
safenetworkjs:container { buf: <Buffer@0x2d91e88 9f 21 01 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 30 2e 34 30 31 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b4014ac0 53 61 66 65 2d 62 72 6f 73 77 65 72 2d 6c 6f 67 2d 30 31 30 39 31 37 2e 74 78 74>,
safenetworkjs:container { buf: <Buffer@0x2d91f00 f4 15 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 31 2e 33 30 37 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b402d690 5f 6d 65 74 61 64 61 74 61>,
safenetworkjs:container { buf: <Buffer@0x2d91f78 01 2f 00 00 00 00 00 00 00 53 65 72 76 69 63 65 20 52 6f 6f 74 20 44 69 72 65 63 74 6f 72 79 20 66 6f 72 3a 20 6a 70 6c 2f 72 6f 6f 74 2d 73 61 66 65 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b401c410 62 6c 75 65 73 2e 6d 70 33>,
safenetworkjs:container { buf: <Buffer@0x2d91ff8 80 3e 0b 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 32 2e 32 36 31 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b401c430 62 6c 75 65 73 32 2e 6d 70 33>,
safenetworkjs:container { buf: <Buffer@0x2d92070 00 a7 0a 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 35 2e 35 34 37 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b402fd00 63 73 73 2f 62 67 31 2e 6a 70 67>,
safenetworkjs:container { buf: <Buffer@0x2d920e8 83 02 01 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 38 2e 34 31 34 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b402fda0 63 73 73 2f 73 74 79 6c 65 31 2e 63 73 73>,
safenetworkjs:container { buf: <Buffer@0x2d92160 30 04 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 30 39 2e 34 31 35 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b402fe40 66 61 76 69 63 6f 6e 2e 69 63 6f>,
safenetworkjs:container { buf: <Buffer@0x2d921d8 be 10 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 31 30 2e 30 33 32 5a 1e 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container { key: <Buffer@0x7f58b4000fe0 69 6e 64 65 78 2e 68 74 6d 6c>,
safenetworkjs:container { buf: <Buffer@0x2d92250 23 03 00 00 00 00 00 00 18 00 00 00 00 00 00 00 32 30 31 38 2d 30 39 2d 31 34 54 32 33 3a 34 32 3a 31 30 2e 38 31 35 5a 1b 00 00 00 00 00 00 00 32 30 ... >,
safenetworkjs:container version: 0 } } ] +54ms
safenetworkjs:container Key : Safe-auth-log-010917.txt +3ms
safenetworkjs:container Object.call returning result: 'not-found' +1ms
safe-fuse:vfs-cache getattr('/_public/jpl/root-safe-blues/hello2') result type: not-found reply(Fuse.ENOENT) +431ms
unique: 345, error: -2 (No such file or directory), outsize: 16
unique: 346, opcode: CREATE (35), nodeid: 11, insize: 63, pid: 6026
create flags: 0x80c1 /_public/jpl/root-safe-blues/hello2 0100644 umask=0022
safe-fuse:ops create('/_public/jpl/root-safe-blues/hello2', 33188) +0ms
safe-fuse:vfs:index getHandler(/_public/jpl/root-safe-blues/hello2) +431ms
safe-fuse:vfs:root getHandlerFor(/_public) - containerRef: { safePath: '_public', safeUri: undefined }, mountPath: /_public +431ms
safe-fuse:vfs:root RootHandler for { safePath: '_public', safeUri: undefined } mounted at /_public create('/_public/jpl/root-safe-blues/hello2') +0ms
(node:5766) UnhandledPromiseRejectionWarning: TypeError: this.getContainer(...).createFile is not a function
at RootHandler.create (/home/user/safe-fuse-test/safenetwork-fuse/src/safe-vfs/root.js:351:40)
at create (/home/user/safe-fuse-test/safenetwork-fuse/src/fuse-operations/create.js:10:38)
(node:5766) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
(node:5766) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
