I’ve tried to summarise how I think some aspects of network storage works, to help me work out how best to use the API and how to implement storage functionality.
I’d like confirmation and corrections as needed - and by all means fill in any relevant things I missed etc (or if this is documented in detail a reference is fine, but looking at the code is hard for me to figure out this detail and takes a lot of time, but I’ve done my best!
Changes to this OP:
- addendum: noting that WHM
_publicdoesn’t seem to be consistent with RFC wrt ‘flat’ directory structure - corrected and annotated in accordance with Gabriel’s first reply below.
Account Structures
- Logging in retrieves an account MD (container) with keys for certain defaults:
_metadata- a reserved key which holds metadata about the container (including name and tag type - anything else?)- permissions - access control information (public keys). Is this a reserved key or something in its own right?
- root containers (keys whose value points to a container), accessible via the following container names:
_publicfor public containers and files (but apps can put anything in an entry)_private, _documents, _photosetc (but not all names implemented yet)_publicNames- for containers corresponding to each public ID
- anything else?
I notice that the values for the container/MD entries are much shorter than the values I’m storing which reference immutable data. So what is the value that’s stored in a key used to reference a container/MD? Is it a network address, or a container name that will be combined with a type tag to retrieve the container itself, or something else? (I.e. For example, what is the value stored in the _public container for a key of /_public/<publicname>/root-www?)
_publicNames Root Container
_publicNamescontainer has a entry for each public name owned by the account, which maps to a services container for the name- the services container has one entry for each service created for the public name, which maps to another public container referencing content (i.e. immutable data/files)
- so for example, resolving a SAFE Browser URL means:
- using the domain portion of the URL to access the services container for that public name (the domain). The container is the MD found at the address, or xorname, given by SHA3(‘
<public-name>’), with type_tag 15001 (SAFE services). - then reading the value of the ‘www’ service entry of the services container, to retrieve the root container (an MD) which holds the files accessible through the service
- reading the value of a named file to get the address of the immutable data for the file (or MD for a directory)
- getting the content at the address and serving in a response
Web Hosting Manager
Question:
- where WHM uploads a folder which has files and a subfolder,
- and where the folder is represented by a public container, say
/_public/mywebsite/root-www, - and the subfolder is represented by a public container, say
/_public/mywebsite/root-www/images, - does the folder container (
/_public/mywebsite/root-www) contain an entry for the subfolder (or only for each file)?
Root Container Entries
The WHM UI assumes that every entry in the _public container refers to a container, even if they are not (I know because it offers file entries - I’ve created there - when I modify a server/container mapping). Is this a problem!? E.g. a WHM or API bug, or bad practice for me to put anything other than a container as an entry in a root public container? Am I supposed only to insert entries corresponding to containers in a root container?
Metadata
- is there a recommended way to set/get metadata for a container (other than name and type tag)?
@bochaco: You can use the MutableData setMetadata function: http://docs.maidsafe.net/beaker-plugin-safe-app/#windowsafemutabledatasetmetadata to set it (you can even set it with quickSetup). We are missing a function to retrieve it though.
An example of use of this metadata is when you request access to share a random MutableData, the authenticator will display it to help the user understand what the MD contains and to decide if it should be allowed or not. - is there a recommended way to set/get additional metadata for files (e.g. content type)?
Mutable Data Operations and Limits
there are a maximum of 1,000 entries per MD, and 1MB in size per MD
when either limit is reached, no more entries can be inserted but changes that don’t violate the limit may succeed (e.g. setting a smaller sized value that decreases the size of 1MB MD)
EntryMutationTransaction::remove does not remove the key. It clears the value and causes the key’s version to be incremented.
what is the
Bufferparameter passed to the Entries::forEach() handler?@bochaco: That’s the entry’s key, look at the example snippet in this section of the documentation: http://docs.maidsafe.net/beaker-plugin-safe-app/#windowsafemutabledataentriesforeach
assuming (as I stated) an account login returns an MD, there’s a limit on the number of root containers it could hold (1,000)
the act of creating new public containers and inserting them into the
_publicroot container will use up entries up to a maximum of 1,000 -
there’s effectively a limit on the total number of public containers (folders uploaded) per account, because each uses up one of the 1,000 entries in
_publicroot container (but this may be further reduced if youremoveandinsertentries for other reasons too (such as renaming a folder causing a key to be deleted and a new entry inserted) -
there’s effectively a limit on the number of files and subfolders that can be uploaded per folder, because each file and subfolder of a folder uses one of the 1,000 entries in the MD container which represents the folder
Thanks for reading, and for any clarifications. I hope this will also help with ideas for what information to add to documentation and tutorials for developers.
__
UPDATE: looking back at my notes on RFC-0046 New Auth Flow - containers.md I see that it is Active but not accepted and does not appear to be reflected in the code based on examining what’s in _public container and looking at the Web Host Manager code. For example it says NFS doesn’t use a hierarchy of containers but a flat key/value structure. This is what I based my RS.js implementation on, but looking at what the Web Host Manager creates I see it does create entries in _public for subfolders which appear to be containers.
For example, after uploading the folders for safe://mywebsite, I see entries in _public container for both '/_public/mywebsite/root-www' and '/_public/mywebsite/root-www/images'. This looks like a heirachy of containers to me, but if not, what is it?
What is the code based on and is this an oversight? Or am I doing (reading) it wrong
NOTE: I don’t know yet, but it seems likely that it will be easier to support a SOLID compatible API if containers are a hierarchy, i.e. NOT as in RFC-0046, but as they appear to be in the code. This is because containers are first class objects in LDP (you can create an empty container) and I think they have metadata but haven’t looked in detail yet.
