First, I’d like to praise @joshuef for the web-hosting-manager-mock release.
I haven’t used it yet, but I really really appreciate it’s existance.
Anyway, I’ve downloaded what I think is the latest linux-x64-dev package (team peruse’s version control is confusing lately), then moved it to /opt/Maidsafe, and ‘chowned’ the directory to root:root.
My problem is that my site appears as empty apart from the title in the tab bar in Peruse while it’s working fine in the beaker browser.
The only error I see from inspect element is the ‘uncaught: …window.eval()’ error.
This is what happens when I start peruse-dev:
[folatt@MyComputer Peruse-dev]$ ./peruse --debug
Started with node env: development
Log location: /home/rogier/.config/Peruse/log.log
Running with derived constants:
isRunningDebug? true
shouldStartAsMockFromFlagsOrPackage? true
isRunningUnpacked? undefined
isRunningPackaged? true
inMainProcess? true
startedRunningProduction? false
startedRunningMock? true
isRunningSpectronTestProcess? undefined
isRunningSpectronTestProcessingPackagedApp? undefined
Main process starting.
App Ready
Unhandled Rejection. Reason: Cannot find module '../screen'
At: Promise {
<rejected> { Error: Cannot find module '../screen'
at Module._resolveFilename (module.js:485:15)
at Function.Module._resolveFilename (/opt/Maidsafe/Peruse-dev/resources/electron.asar/common/reset-search-paths.js:35:12)
at Function.Module._load (module.js:437:25)
at Module.require (module.js:513:17)
at require (internal/module.js:11:18)
at Object.get [as screen] (/opt/Maidsafe/Peruse-dev/resources/electron.asar/browser/api/exports/electron.js:11:16)
at e.exports (/opt/Maidsafe/Peruse-dev/resources/app.asar/main.js:9:306079)
at f (/opt/Maidsafe/Peruse-dev/resources/app.asar/main.js:9:102876)
at App.<anonymous> (/opt/Maidsafe/Peruse-dev/resources/app.asar/main.js:1:103918)
at Generator.next (<anonymous>) code: 'MODULE_NOT_FOUND' } }
In case I’m supposed to run peruse-dev as superuser,
I get this when I start Peruse as superuser:
Problems starting internal peruse server
Error: listen EADDRINUSE 127.0.0.1:3984
at Object.exports._errnoException (util.js:1024:11)
at exports._exceptionWithHostPort (util.js:1047:20)
at Server.setupListenHandle [as _listen2] (net.js:1319:14)
at listenInCluster (net.js:1367:12)
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1493:7)
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
errorInWindow Uncaught Error: listen EADDRINUSE 127.0.0.1:3984
Background process renderer loaded.
OnOpen: Setting mock in store. true
Authenticator lib status: true
Wrapping Address bar buttons LHS
Triggerin auth URL decode { id: 2980551291,
uri: 'safe-auth:AAAAAHuap7ECAAAAGwAAAAAAAABuZXQubWFpZHNhZmUucGVydXNlLWJyb3dzZXI' }
Authenticator.js decoding request safe-auth:AAAAAHuap7ECAAAAGwAAAAAAAABuZXQubWFpZHNhZmUucGVydXNlLWJyb3dzZXI
IPC.js: another response being parsed.: { error: null,
res: 'safe-bmv0lm1hawrzywzllnblcnvzzs1icm93c2vy:AQAAAHuap7ECAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA',
type: 'DESKTOP',
authFromInternalResponse
previousState: null
Error at req processing for: { error: 'Cannot read property \'auth_unregistered_decode_ipc_msg\' of null',
res: null,
type: 'DESKTOP',
This results in the titlebar and perhaps menubar as well missing, unless that’s meant to be, but I don’t think it is.
