Site: https://gitlab.com/UniversalBasics/Yropeen/Site-Yropeen
OS: Arch Linux
Browser: Beaker
env: mock
For whatever reason all my dropdown menus have disappeared.
I have these dependencies:
"dependencies": {
"babel-helper-module-imports": "~7.0.0-beta.3",
"mdbootstrap": "4.5.5",
"mdbvue": "~4.5.0",
"vue": "2.5.17",
"vue-router": "~3.0.0"
"devDependencies": {
"@neutrinojs/vue": "~8.0.0",
"babel-plugin-transform-runtime": "~6.0.0",
"babel-preset-stage-2": "~6.0.0",
"eslint": "~4.19.0",
"eslint-config-standard": "~11.0.0",
"eslint-plugin-import": "~2.13.0",
"eslint-plugin-node": "~7.0.0",
"eslint-plugin-promise": "~3.8.0",
"eslint-plugin-standard": "~3.1.0",
"eslint-plugin-vue": "~4.7.0",
"jquery": "~3.3.0",
"neutrino": "~8.3.0",
"webpack": "~3.11.0"
I do have an error besides the usual ones in browser console.
Uncaught (in promise) Error: Unexpected (probably a logic error): Could not connect to the SAFE Network
at module.exports (/opt/Maidsafe/safe-browser-mock/resources/app/node_modules/@maidsafe/safe-node-app/src/native/_error.js:19:10)
at ffi.Callback (/opt/Maidsafe/safe-browser-mock/resources/app/node_modules/@maidsafe/safe-node-app/src/native/_app.js:63:22)
at /opt/Maidsafe/safe-browser-mock/resources/app/node_modules/ffi/lib/callback.js:66:25
at Function.proxy (/opt/Maidsafe/safe-browser-mock/resources/app/node_modules/ffi/lib/_foreign_function.js:59:14)
at Promise (/opt/Maidsafe/safe-browser-mock/resources/app/node_modules/@maidsafe/safe-node-app/src/native/_app.js:72:14)
at Promise (<anonymous>)
at Object.app_registered (/opt/Maidsafe/safe-browser-mock/resources/app/node_modules/@maidsafe/safe-node-app/src/native/_app.js:59:16)
at lib.decode_ipc_msg.then (/opt/Maidsafe/safe-browser-mock/resources/app/node_modules/@maidsafe/safe-node-app/src/api/auth.js:366:22)
at <anonymous>
