hey @0mkara, before calling the SAFE APIs (which are written in Rust), you need to load the native libraries into memory. This is done by calling the following function:
Thanks for the info. Now I try to load native libraries like following.
Client.load(ChatActivity.instance)
I get another error after this
E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.myorg.safe.safeapp, PID: 15088
java.lang.UnsatisfiedLinkError: dalvik.system.PathClassLoader[DexPathList[[zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/base.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_dependencies_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_resources_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_0_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_1_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_2_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_3_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_4_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_5_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_6_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_7_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_8_apk.apk", zip file "/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/split_lib_slice_9_apk.apk"],nativeLibraryDirectories=[/data/app/com.myorg.safe.safeapp-ynZUtctTQHKunqVefs_b3A==/lib/x86, /system/lib]]] couldn't find "libsafe_app_jni.so"
The Client.load() API requires the application context in order to get the app’s files directory to copy and load the native libraries. Does ChatActivity.instance return the context of the application?
That’s strange. How have you included the dependency in your project?
If you could please share your code in a repository, we can try to reproduce the issue on our end too. Thanks
After a quick glance I see that you’ve mentioned the x86 ABI in your build.gradle file.
The safe-app-android package is supported only on platforms with x86_64 or armeabi-v7a support. So trying to load the libs on a x86 emulator is probably the cause of the error.
EDIT: I fired up my x86 emulator and I was able to reproduce your error. Switching to a supported device / emulator will solve your issue.
Ok I changed my emulator to x86_64. Now I get a new error
Process: com.mathcody.safe.safemsg, PID: 6366
java.lang.BootstrapMethodError: Exception from call site #151 bootstrap method
at net.maidsafe.api.Session.setAdditionalSearchPath(Session.java:139)
at net.maidsafe.api.Client.load(Client.java:36)
at com.mathcody.safe.safemsg.ChatActivity.onCreate(ChatActivity.kt:26)
Caused by: java.lang.ClassCastException: Bootstrap method returned null
The safe-app-android library uses some Java 8 features. In order for your project to support this you will need to add the following in the android block of your build.gradle file.
Thanks for the info @lionel.faber. This finally solved the issue.
Now there is a new issue. The app screen seems to keep flashing in some infinite loop. Although I see no error but logs say
/OpenGLRenderer: Davey! duration=828ms; Flags=0, IntendedVsync=6852234425328, Vsync=6853001091964, OldestInputEvent=9223372036854775807, NewestInputEvent=0, HandleInputStart=6853016166220, AnimationStart=6853016236000, PerformTraversalsStart=6853016318050, DrawStart=6853017864740, SyncQueued=6853019519700, SyncStart=6853021080060, IssueDrawCommandsStart=6853021137700, SwapBuffers=6853039065080, FrameCompleted=6853064294770, DequeueBufferDuration=203000, QueueBufferDuration=794000,
W/ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@40a35bf
I/JSA: set Tag for ViewHolder, position: 0
I/JSA: set Tag for ViewHolder, position: 1
W/ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@c50ebc1
D/EGL_emulation: eglMakeCurrent: 0x7b08ac0724a0: ver 2 0 (tinfo 0x7b08ac00dcc0)
W/ActivityThread: handleWindowVisibility: no activity for token android.os.BinderProxy@5250233
I had a look at the latest code in your repository and I’ve identified the issue. In your Android Manifest you have registered the safe-auth scheme for your application. The safe-auth scheme is registered for the SafeAuthenticator mobile application.
Encoding a request, prepending it with safe-auth and opening it will redirect you to the authenticator which can process the request. Since your application is registered with safe-auth when you send the auth request it starts the same application again, which sends another auth request and it’s stuck in an infinite loop.
The scheme that has to be registered for your application is your application’s ID. com.mathcody.safe.safemsg in this case.
Caused by: android.content.ActivityNotFoundException: No Activity found to handle Intent { act=android.intent.action.VIEW dat=safe-auth://com.mathcody.safe.safemsg/bAAAAAAALQKL7KAAAAAABSAAAAAAAAAAAMNXW2LTNMF2GQY3PMR4S443BMZSS443BMZSW243HAEAAAAAAAAAAAAAMAAAAAAAAAAAFGQKGIUQEK6DBNVYGYZIIAAAAAAAAAAAG2YLUNBRW6ZDZAEAAAAAAAAAAAAAB }
