Environment
Server
sn_node: 0.25.39
sn_cli: 0.17.2
sn_auth: 0.0.15
Operating System: 5.4.81-1-MANJARO-ARM aarch64
Client
sn_node: 0.25.39
sn_cli: 0.17.2
sn_auth: 0.0.15
Operating System: 5.4.89-1-MANJARO x86_64
Steps
Server
safe
node run-baby-fleming --ip my.lan.ip.address
auth restart
auth create --test-coins
auth unlock
auth unlock --self-auth
files put /home/folaht/safe/bonjour_chacun.txt
cat safe://source_path
Client
echo "\"my.ip.v4.address:12000\"" | tee ~/.safe/node/node_connection_info.config
safe
networks add mynetwork
networks switch mynetwork
Expectations
A Bonjour chacun ! on both server and client.
Results
Server
> cat safe://hyryyry96hxxe5rygh5b1qfp7hi3jxtefkepj4prq8gif487tkapbords1ynra
Bonjour chacun !
Client
[2021-01-31T22:59:02Z ERROR qp2p::api] Failed to bootstrap to the network: Connection lost
[2021-01-31T22:59:32Z ERROR qp2p::api] Failed to bootstrap to the network: Connection lost
[2021-01-31T23:00:02Z ERROR qp2p::api] Failed to bootstrap to the network: Connection lost
[2021-01-31T23:00:02Z ERROR safe] sn_cli error: Failed to connect: [Error] ConnectionError - Failed to connect to the SAFE Network: QuicP2p(BootstrapFailure)
