Can not join node from one Ipv6 machine to another.
Environment
Server 1 & 2
sn_node: 0.26.7
sn_cli: 0.18.0
sn_auth: 0.1.0
Operating System: 5.4.81-1-MANJARO-ARM aarch64
Steps
Server 1
~/.safe/sn_launch_tool -d ~/.safe/node/nodes -n11 --ip my.ipv6.server1.address
Server 2
safe networks add folaht
echo "\"[2001:983:8610:1:854:efb1:52e6:85a3]:12000\"" | tee ~/.safe/cli/networks/folaht_node_connection_info.config >/dev/null
safe networks switch folaht
Expectations
Node joins folaht’s safe network.
Results
Server
Running sn_node v0.26.7
[sn_node] ERROR 2021-02-06T02:47:20.793189175+01:00 [src/bin/sn_node.rs:119] Cannot start node due to error: Routing(Network(BootstrapFailure))
If this helps, in order to join your network as per @tfa hack to the client.config file, I had to delete the node_connection_info.config file in .safe/node , otherwise that was the file that was used to launch the node
I’ve started looking at having a command for setting up a network in CLI’s config from a IP:port: https://github.com/maidsafe/sn_api/pull/710
I’m initially going for having an additional networks set subcommand that it can receive IP:port (both ipv4 or ipv6) as opposed to networks add which expects a URL for where to pull the connection info from. So e.g.
$ safe networks add maidsafe-testnet https://sn-node-config.s3.eu-west-2.amazonaws.com/shared-section/node_connection_info.config
Network 'maidsafe-testnet' was added to the list. Connection information is located at 'https://sn-node-config.s3.eu-west-2.amazonaws.com/shared-section/node_connection_info.config'
$ safe networks set folaht-ipv6-testnet [2001:983:8610:1:854:efb1:52e6:85a3]:12000
Network 'folaht-ipv6-testnet' was added to the list. Contacts: '{[2001:983:8610:1:854:efb1:52e6:85a3]:12000}'
$ safe networks
| Networks            |        |
| Network name        | Connection info        |
| folaht-ipv6-testnet | {[2001:983:8610:1:854:efb1:52e6:85a3]:12000}                                                 |
| maidsafe-testnet    | https://sn-node-config.s3.eu-west-2.amazonaws.com/shared-section/node_connection_info.config |
Thoughts?
