[Ignore:
DataMap, a part that belongs to the metadata, will be updated though for every change of file you publish to the network. If you want DataMap updates to not affect the metadata (which is stored in the parent dir) - the only way i can immediately think of is via the indirection : store is separately in SD (because SD’s are the only ones whose ID does not change even if data changes). That is what i mentioned here. And that will have all the problems in the post i tagged you.]
Edit: Ah shit - i missed the first part of the quoted sentence:
Yes this we can do and is currently done that way - the DataMap is returned (and hence the metadata with the parent updated) only after the final chunk is put out. Though right now the chunks are put serially i think they can be made to go parallely - although it affects the precision of the progress bar the fontend wanted (i know i know - tell them ).
[Btw does anyone know how to do a strike through - instead of Ignore i wrote above.]
I don’t feel knowledgeable enough to make sensible judgements about implementation issues here, so my thoughts are fairly high level and more user than builder or implementor oriented.
As a user, my preference was always 3, but until @Fraser intervened, it seemed pointless to advocate that based on what was said in the OP, because I couldn’t address the objections made against it.
As a user, I’ve never used Google Docs to a significant extent, so I think of filesystems in terms of Windows & Linux, particularly backup/restore (as in the kind of applications Fraser mentioned, and similar) and assume (perhaps incorrectly) that those cover most common user expectations and use cases well.
For anything else, of course providing the low level tools is very important.
So with the caveats about my input I’ve given, my preference is for the NFS level functionality include the ability to really roll back to version based on directory level, including deleted files. That makes it easy to restore whole trees, and even to find a particular version of a file at a given date even though the file versions aren’t indexed separately (but that would then be fairly easy to add in an App).
In this I don’t have much sense of performance issues, and I do agree that thinking differently with this new, er [hesitates,] paradigm [ducks] is both where the gold lies, and bloody difficult.
Fair enough - i have asked @Fraser to further elaborate on it to view merits demerits better and to understand what he exactly views as directory versioning and version restoration.
To probe further - if you have root/a/b/c (snapshot-0), then root/a/b (snapshot-1), and so on. What do you mean by backup/restore ? Should the travel from snapshot-0 to snapshot-1 be reflective in root ? Something like root-v0 and root-v1 so when you say root-v0, you are no longer prompted which version of a once you enter it, and then not prompted which b etc. All that will happen is if you chose root-v1 you would expect is - i enter it, find a, enter it find b enter it find nothing <<< Would this be your expectation ?
So going to a given version of root is unambiguous - you get it as it was at that time.
I failed to recall the name of another backup system which works like Apple’s time machine and which I used, but you’ve reminded me: rsnapshot
rsnapshot is a great set of scripts that uses links to minimise the file storage space needed to preserve the file tree at each snapshot. What’s nice is that it creates a tree in the filesystem with a copy of each snapshot in it, which means you can explore the tree with all the normal filesystem tools. Each time a snapshot is generated, only changed filles are copied to the tree, if a file is unchanged, a link is created instead, so each version of a file is only stored once.
Ha! Right - saving the chunks sequentially to allow the UI to easily report progress sounds like the wrong solution to that particular problem, but I sense I am preaching to the choir there!
So, if we can multiplex uploads and get the progress correctly reported, we are on to a winner?
Should be doable (can’t promise until flushed out though - i am not a cheerful person, pessimist until done kind of a guy ). Thanks for all your opinions so far.
I need to try and get time to put together an RFC for SD which would allow us to get rid of AppendableData and make it as flexible as possible without complicating it. I’m convinced this is do-able. That SD would keep previous versions (where the current one doesn’t) so long story short, we wouldn’t then need DirListing and hence DirMetadata::locator would just point to an SD representing an encrypted Dir rather than DirListing - but that’s not essential to change to use dir-versioning.
I’m still failing to see how dir-versioning is more complex. I think I must be misunderstanding something here… this is how I see the flow for basic file ops under each approach:
File-Versioning:
To add a versioned file:
Create FileMetadata and store as new SD::data(Vec<FileMetadata>)
Add File to parent Dir::files and store new version of SD::data(encrypted(serialised(Dir)))
To modify a versioned file:
Update FileMetadata in parent Dir::files and store new version of SD::data(Vec<FileMetadata>)
To delete a versioned file:
Delete SD::data(Vec<FileMetadata>)
Remove File from parent Dir::files and store new version of SD::data(encrypted(serialised(Dir)))
Dir-Versioning:
To add a file:
Add FileMetadata to parent Dir::files and store new version of SD::data(Vec<encrypted(serialised(Dir))>)
To modify a file:
Update FileMetadata in parent Dir::files and store new version of SD::data(Vec<encrypted(serialised(Dir))>)
To delete a file:
Remove FileMetadata from parent Dir::files and store new version of SD::data(Vec<encrypted(serialised(Dir))>)
Edit: Forgot that SDs don’t handle versions again, so changed SD::data(encrypted(serialised(Dir))) to SD::data(Vec<encrypted(serialised(Dir))>) for dir-versioning list.
Consider: root/a/b/c in which root is at version 3 == root-v3. Now next snapshot is root/a/b. In your method (and i might be wrong here) what i believe will happen is version of root remains root-v3. You enter root, you get the latest version of a by default, and then latest version of b (which does not have c).
But if you read what ppl expect, they seem to want root-v3 progress to root-v4 with that operation. Now if you wanted to view root-v3 it should fetch (by default) a corresponding to that time, entering that, b corresponding to that time which containsc. So it’s like a whole backup-restore kind of operation. This is certainly more complex.
There is no root-v4 though! Root didn’t change, so I think it would be pointless to add a new version with the same details as the previous. I guess you’re implying that every dir-listing in the entire tree should change with every snapshot (i.e. every time any dir is changed, they all are)?
For user to “see” the v4 snapshot, they have to recurse down the tree anyway, right? So, if we only update the specific dir affected rather than doing a full snapshot kinda thing, then to view this, the user would pull the root, parse it, find out about a, pull its listing, parse and so on… When they get to b, they find two versions, say b0 and b1. It’s up to the app how it wishes to display that info. If it’s only presenting the current state, it only parses b1 and shows dir b with no dir c. If it’s trying to present the state from a time point before b1 was added, it parses b0 and shows dirs b and c.
yes that is also what i expected - but that’s not what people seem to think about it - i specifically asked if it was viewed as a entire tree snap-shot (like backup/restore) and the answer was yes.
@happybeing - would you be ok if it was like what fraser is saying ? (It’s not like a conventional snapshot tree backup/restore opreration - would you still prefer it ?)
@Fraser: Another point - with file only versioning, only one thing would grow - that particular file’s metadata vec.
So root/a/file-v0 then root/a/file-v1 would imply when you fetched SD::data(a) you would have fetched:
struct Dir {
sub_dir: Vec<DirMetadata>,
files: Vec<File>,
// where roughly
enum File {
Versioned(Vec<FileMetadata>),
Unversioned(FileMetadata),
So you can see, if a had 50 KiB of data (i.e. if sizeof(Dir-for-a) == 50 KiB) then new version of file would only cause a slight increment in size (previous size + size of new file’s metadata). Say the increase is 1 KiB. So now total size is 51 KiB. Assume next time it would be 52 KiB. But in dir versioning you would replicate the entire 50 KiB (as SD::data(a) is now SD::data(Vec<a>)) => new SD size ~ 101 KiB and probably kicked out of the SD. Next time 153 KiB etc. So in 3 updates for a file you would have reached 52 KiB in the file only versioning but 153 KiB in dir-versioning.
Yes I think it is still preferable, though not quite as much!
Clearly more work than my initial interpretation, but it still seems more intuitive to look for beginning at a directory level - because wet group files together that way for a reason.
If I understand it correctly, the same information can be reconstructed from versioning files - it does though seem like it could be more work (processing) to reconstruct the state of a given directory, and I think that’s a common use case and likely to remain so.
I am though uncertain about all this and interested to hear contra arguments because I’m very much in learning mode - and I love to learn. This is to me a fascinating discussion, and is helping me understand more about the SAFEnetwork and maybe one day, where some of those gold nuggets are hidden
We evaluated both file and directory versioning and each have their strengths and disadvantages currently. We need to factor in the way SAFE Network works into our discussions as well otherwise the practical outcome will be skewed. One drawback of file versioning is one wouldn’t be able to retrieve a deleted file, but this can be worked around by client apps storing a copy of it somewhere if this functionality is wanted, for e.g. they can move the deleted items to trash before deleting from directory listing for recovery of accidentally deleted items. From a different perspective however this feature of not being able to recover deleted files might be useful - maybe the user had sensitive information and wanted a permanent and secure deletion.
With Dir versioning the disadvantages are those of sizes. If a file is changed in the dir then entire directory is replicated with the new file causing more bloat. This is explained here. Similarly if there are many files which do not require versioning support (just a few or one requires it) then they all suffer due to entire dir being versioned. This size issue with Directory versioning can be countered with only keeping a diff of changes when a dir is mutated. This will however need to be looked into in a separate topic before concluding as feasible. The good however is that a deleted file can be recovered (which again comes with a caveat - if someone does want a truly permanent deletion it wouldn’t be (at least not easily) possible).
This also ties in with self-encryption. Since ImmutableData is capped at 1 MiB currently, we want S.E to reflect that by giving us a DataMap by way of recursive s.e which is <= current cap for ImmutableData. This code is presently in safe_core and is currently planned to be moved to S.E.
Ultimately we will also discuss more on whether deletable-immutable-data might help here, reducing unwanted data from the Network. The RFC is already there for a starting point.
With all this we concluded that for now we will go with File-versioning approach (which suffices a lot of use cases already) and keep looking for any solution that can be better overall as our network matures and we know more of what might pan out and what might not.
