Problem with latest safe-authenticator-cli
Yes, it still fails unfortunately.
Edit. I don’t have wget installed but ping and curl both fail.
 $ ping localhost:15000
    Ping request could not find host localhost:15000. Please check the name and try again.
 curl localhost:15000
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:00:01 --:--:--     0curl: (7) Failed to connect to localhost port 15000: Connection refused
Edit 2: installed wget:
$ wget localhost:15000
--2019-08-09 16:30:49--  http://localhost:15000/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:15000... failed: Bad file descriptor.
Connecting to localhost (localhost)|127.0.0.1|:15000... failed: Bad file descriptor.
right, so it seems it has to do with some firewall or something blocking http reqs to localhost/127.0.0.1, perhaps you can try to disable any firewall you may have for localhost ?
Just to be annoying, these commands above work fine here on Ubuntu with the latest updates this afternoon.
I’m leaning towards a firewall problem myself…
I can’t see anything obvious blocking it and I have whitelisted safe.exe and the authenticator. Also if I run create-react-app on localhost:3000 wget reaches it fine…
Edit: turned the firewall off - same thing.
It could just be this machine. If you remember I was having problems with WHM hanging and WebIDs (we tried to resolve them over Hangout) which are fine on another Win 10 machine.
Yes, that is quite annoying …
sorry to be annoying, but I only have a few Core Skills and Annoying is one of them…
Yeah I imagined it was that PC again :slight_smile: , I just searched quickly and there are a few people there with similar issues on Windows10. So if you run safe_auth on port 3000 does it work?
Also, wondering if using 127.0.0.1 makes any difference for you, would it if you do wget 127.0.0.1:15000 ? if so then changing this line to use 127.0.0.1 should fix it: https://github.com/maidsafe/safe-cli/blob/master/src/api/auth.rs#L19. From what you mentioned about wget-ing port 3000 it was with localhost so I assume it won’t make any diff, but just double checking
Hi @bochaco
Nope.
Also nope. Same error.
Incidentally, should I be able to see anything if I browse to localhost:15000? Currenly I’m getting ‘unable to connect’
Another thing. I have this working (I think) on Ubuntu now, but
cargo run --features mock-network -- -i sdfsd --daemon 15000 is now asking me for a secret and password, which didn’t happen on Windows.
What secret and password do I use by the way?
That’s because of the --invite/-i arg, the safe_auth assumes you wanna create a new account, so you should enter any new secret/pwd you like for that new account. If you omit that arg, it assumes you wanna log in using an existing account and you’ll need to enter the secret/pwd for an existing account.
I’m duck-ing (duck-duck-go-ing :stuck_out_tongue: ) to see if I find some other solution or potential root cause for this, I honestly have no clue. I’m also starting to suspect if the server we use in safe_auth is somehow different from others as you say a react_app server works on port 3000 but safe_auth desn’t
It seems you won’t be able to connect with any client, neither wget, safe_cli or a browser…so…
Let me know if you can think of any others I could try for test purposes.
I’l spark up another Windows machine later see if it has the same issues.
Yes, I figured that was probably the case.
I just created this “hello world!” which listens on port 15000, can you give it a shot by running this and see if you can connect to it with curl or any of the clients on port 15000?
git clone https://github.com/bochaco/rust-hello-world.git
cd rust-hello-world
cargo run
Yes that one works. Hello World in the browser and wget fetches the index.
Nice! ok, give me a sec…
Well…It’ll be a few minutes :slight_smile: I think the problem is the actix-web package we use, the latest version seems to work on windows for you, so presumably they fixed some issue, I’m trying to get a branch and PR for safe_auth to upgrade it and we can give it a try @JPL
Ok, @JPL, whenever you have the chance, can you please give it a try to run my fix-windows10 branch of safe_auth? GitHub - bochaco/safe-authenticator-cli at fix-windows10
You should be able to choose the port as before, I’m just trying to upgrade actix-web which seems to be the issue, we’ll see…
Ah that one wouldn’t build. First error:
   Fresh actix-web v1.0.5
error[E0432]: unresolved import `routing::Client`
  --> C:\Users\John\.cargo\git\checkouts\safe_client_libs-78dcb58b240b6e71\1c9e5f3\safe_core\src\client\core_client.rs:12:5
12 | use routing::Client as Routing;
   |     ^^^^^^^^^^^^^^^^^^^^^^^^^^ no `Client` in the root
I think you forgot to set the mock-network feature, make sure you run it with:
cargo run --features mock-network -- -i fdgfd --daemon 15000
For what its worth - this is what I get
willie@sputnik:~/projects/maidsafe/bochaco/safe-authenticator-cli$ cargo build --features mock-network
   Compiling safe_authenticator v0.9.1 (https://github.com/bochaco/safe_client_libs?branch=temp-experimental#b40de6d0)
   Compiling safe_core v0.32.1 (https://github.com/bochaco/safe_client_libs?branch=temp-experimental#b40de6d0)
   Compiling safe_auth v0.0.1 (/home/willie/projects/maidsafe/bochaco/safe-authenticator-cli)
    Finished dev [unoptimized + debuginfo] target(s) in 32.93s
willie@sputnik:~/projects/maidsafe/bochaco/safe-authenticator-cli$ cargo run --features mock-network -- -i fdgfd --daemon 15000
    Finished dev [unoptimized + debuginfo] target(s) in 0.23s
     Running `target/debug/safe_auth -i fdgfd --daemon 15000`
Secret:
Password:
Exposing service on 127.0.0.1:15000
thread 'main' panicked at '
!   unwrap! called on Result::Err                                              !
src/authd.rs:37,18 in safe_auth::authd
Err(Os { code: 98, kind: AddrInUse, message: "Address already in use" })
', /home/willie/.cargo/registry/src/github.com-1ecc6299db9ec823/unwrap-1.2.1/src/lib.rs:67:25
note: Run with `RUST_BACKTRACE=1` environment variable to display a backtrace.
Yes I know its Linux and @JPL problem is with windows. Just if it helps…
And if you want me to butt out, just say so :slight_smile:
I’m keen to see this work cos I need to set up a Win10 VM for another project ( helping a mate with a dissertation on hardware wallets) and it would be good to be able to get some Windows experience with SAFE as well.
Oh no. Someone who’s beset by exclamation marks is much less annoying than someone whose build just sails through without a passing remark.
@southside the error you are seeing is because port 15000 is already used in your PC, perhaps you have the other safe_auth in another console running? in any case try with a different port and should be ok.
@JPL let me know if you try with the mock-network feature since the build error you saw is just that for sure
