This is an interesting thread and very useful in trying to figure out the best design patterns to use with the SAFE API and storage model.
A couple of thoughts:
This is tricky. One thought is where individuals share things the app creates a ‘salt’ for each user, and when sharing with trusted friends this ‘salt’ could be shared. So users of hash(title) the xor address to find things I share with you would be hash(title) ^ happybeing's salt
Clunky, the salts would be stored by your app, so if @bochaco texts me Hey happybeing, check out ‘Soda Stereo’ I paste ‘Soda Stereo’ into JAMS and when it comes up with not found it prompts Check friend uploads? and when I choose @bochaco from the list it can find the file by using his ‘salt’.
Ugly, so maybe not a great idea. Into thought number two…
To handle the problem of Gabriel sharing a playlist with me or anything else with editable data (music library index) there are two options, and apps can do either A or B, or offer this as a configuration setting, or prompt etc
A) Store a pointer to the Mutable Data. Pro: simple, cheap (1 PUT) Concensus: when Gabriel changes his MD I might lose stuff I wanted to keep (eg a particular music file) or worse, be deceived into downloading something harmful (malware, porn, an advert for Coka Cola etc)
B) Store a Copy of The Mutable Data, including a pointer back to the original). Pro: I have both the original and my own copy which I can edit Con: it could cost more (depends on the size of the index).
C) Store a Copy of the Mutable Data in an Immutable Data, and add a mutable data if I ever want an edited version (which could just store changes). Pro: maximum functionality - never lose the original, can see/track Gabriel’s changes, can have my own changes on top of the original or in top of Gabriel’s latest. Con: more complexity, cost depends because using Immutable Data might be cheaper than B) until you start editing at least.
