I am having trouble with committing random public md structures to the network and I am met with the error -103: Core error: Routing client error -> Requested data not found
. To recreate go to safe://codeplay.discover and authorise, afterwards create a new random public md and use quicksetup to commit it to the network then retrieve the mdName of the structure and save it. Now refresh the page and authorise again but this time click on new public md and in the name field put in the mdname saved earlier with quotes and if you try to getversion or entries you are met with the error -103: Core error: Routing client error -> Requested data not found
. I can confirm this is on both the latest browsers on linux with solus . Also you can access the md version and see the entries from quick setup before refreshing the page.
Another issue is the safe://codeplay.discover website isnât able to upload files, when you try to create a NFS file you are met with TypeError: First argument must be a string, Buffer, ArrayBuffer, Array, or array-like object.
