Using my previous simple example, packaging with pkg:
$ pkg --targets host index.js
> pkg@4.3.1
Gives the following result upon execution:
$ index.exe
ERROR: Error: Dynamic Linking Error: Win32 error 126
at new DynamicLibrary (C:\snapshot\test\node_modules\ffi\lib\dynamic_library.js:74:11)
at Object.DynamicLibrary (C:\snapshot\test\node_modules\ffi\lib\dynamic_library.js:33:12)
at Object.ffi.init (C:\snapshot\test\node_modules\@maidsafe\safe-node-app\src\native\lib.js:20:15)
at new SAFEApp (C:\snapshot\test\node_modules\@maidsafe\safe-node-app\src\app.js:36:9)
at Object.initializeApp (C:\snapshot\test\node_modules\@maidsafe\safe-node-app\src\index.js:61:25)
at authorise (C:\snapshot\test\index.js:0:0)
at __dirname (C:\snapshot\test\index.js:0:0)
at Object.<anonymous> (C:\snapshot\test\index.js:0:0)
at Module._compile (pkg/prelude/bootstrap.js:1243:22)
at Object.Module._extensions..js (module.js:644:10)
(node:15456) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): Failed to load native libraries: Error: Dynamic Linking Error: Win32 error 126
(node:15456) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero
exit code.
Error 126 means the library is not found.
I figured out that we can give an option to initializeApp and fromAuthURI to specify the path to append to the library searching: libPath. So, the following worked out well:
const path = require('path');
const app = await safeApp.initializeApp(info, null, {
libPath: path.join(path.dirname(process.execPath), './node_modules/@maidsafe/safe-node-app/src/native')
This will be put together with the name of the library (src/native/lib.js#L33) and it will be found. (Assuming relative to the executable the node_modules directory is located containing the built @maidsafe/safe-app-node package with its libraries.)
I think I’ll be refining this to make some kind of repository that will use any of this to make a packagable test app.
